Hose Clutch bearing replaced by Lubricator
Hello Everybody
I need your experience for my request.
On my 170S 1950th project , I'd ever dismantle all the central lubrication system.
I'd installed some lubricator for all the " front axle points needed" and that points could be greasing now manually.
But my question is for the clutch , how I can do afterI had dismantle the grease hose clutch bearing ,
I mean what I can put inside de new lubricator bearing : some grease ? oil , Or ? and also how ??
Thanks for your pertinent reply
Best regards
Take care
Friendly
Marc
Best regards
Take care
Friendly
Marc
Re: Hose Clutch bearing replaced by Lubricator
Hello Gentleman
After reading a lot and searching on our excellent forum, I found and get information for my modification....
I understand that some owners had replaced the 170 S clutch bearing by a 180 Ponton model witch is full life greased .
Ok perfect,
but did someone know the exact reference I had to order ?
Did I have to change only the bearing or also a full complete set .
Seems that the "fork sytem" is not the same between 180 and 170 models even the engine is the same (M136)
Did someone can help me on that issue ???
In advance thanks a lot for all
Best regards
Marc
Ok perfect,
Best regards
Marc
Hi Marc,
you can find the bearing here: https://www.automobilia-versand.de/de/a ... r-170.html
it is a closed system and does not need the external lubrication via the "Zentralschmierung"
regards
Reinhard
regards
Reinhard
Hello Reinhard
So many thanks for your help !!!! Really appreciate ....
Ok I'd just now ordering that bearing on Automobilia Versand shop with other items I'd forgetten last time ..
Just another question please , did you know if its possible to use some oil for example with "normal" lubricator (mean used normally for grease ) did I have a risk of leaking ? , in fact as I'd taking out all the original central lubrication system and replaced all by lubricators , i just want to know if I can use normal oil
Another time thanks for your patience !!! its my first MB 170 ( not the last one ...) and I learn all day's even though it has been a long time since I have been to school and my hair is very white...
Friendly
Marc
Friendly
Marc
Hello Marc,
for the central lubrication system you should use Hypoid 90 oil.
regards
Reinhard
regards
Reinhard
Hello Reinhard
Another time thanks for your reply !!
Ok for the Hypoid oil 90 . But just one point , can I use that oil on grease lubricator ? Can it leak ?
Thanks for your patience
Vielen danke
Vielen danke
Hello Gentleman
Just for closed that subject, I've installed the clutch bearing from Automobilia Versand Company used as a closed system ( Thank's Audax!!) , but I'd stay with a lubricator in case off..
Thanks for the information's
- IMG_9574 - Copie.JPG (36.78 KiB) 35406 mal betrachtet
Marc,
you can leave the hole open, you do not need the lubricator pin.
regards
Reinhard
regards
Reinhard
- bearing1.jpg (13.22 KiB) 35391 mal betrachtet
Ok Reinhard I,ll do that ...
Thanks a lot
Thanks a lot
