"ZIERLEISTE VERCHROMT" for 170Sb W191
If you would like to post any questions or comments regarding your Mercedes 170 but you don't speak German - this is your place...
BENZNARD
Beitrag von BENZNARD »
Hello MERCEDES BENZ 170 friends
For a 170Sb W191 , I'm looking for the "zierleiste verchromt' for the rear window seal
I did not find it with the well known seller (Niemoller, Jelinek, Karasch ect.....)
Does someone can help me ?
Many thanks for your help
"Gruss aus Frankreich"
BERNARD
James Allen
Re: "ZIERLEISTE VERCHROMT" for 170Sb W191
Beitrag von James Allen »
Hello Benard, I Not a good German speaker and according to my wife a very bad French speaker. But somehow I manage to get across the street. I am not familiar with the details of the SB rear windshield. But have you tried Lother Meier in Celle? He may have the profilr material to from the required trim part.. He has many important brass profiles for our cars in his program. I believe his son is now running the business. It is just a chance and another place to try. Good luck. Jim
Good Morning Bernard,
please find a Zierleiste verchromt in eBay under eBay-Artikel Number 326694863683 for 149,-€. I guess you have to renew the chrome surface, it costs maybe ca. 50,- €.
Greetings
Hallo Uli and also Bernard,
the eBay offer is too much expensive, when there is no good chrome. New chrome on this part will be cost more than 50 €.
I got some of them refreshed last year. One of them had cost 120€ plus the taxe! And all kind of chrome where refreshed in Poland, made by carways international.
I only got one of them in my garage for the rear left side. It have to be repaired. The repair will cost 85€.
Bernard, I can give you this part for 20€, when you want to repair and refresh it.
Best regards Ralf
Hallo Bernard,
for explaine, I think you mean this part.
Greets Ralf
Rueckspiegel
Beitrag von Rueckspiegel »
Also ich gehe eher davon aus, dass er den Chromrahmen für das Heckfenster vom 170SB/ 220 sucht.
... so habe ich das auch verstanden ...
Ein weiteres Angebot gibt es bei Kleinanzeigen unter der Anzeigen-ID 3148642753,
viele Grüße
uli
Hallo Uli,
jetzt hab ich’s auch richtig gelesen, rear seal, also Dichtung.
Ok, das ist natürlich was anderes, dennoch wird 50€ fürs verchromen nicht hinkommen.
Für W191 und 136 (nur S-V/S-D) gibt es zweierlei. Einen vollchromrahmen aus Messing und einen schmaleren aus Aluminium, der unten geteilt ist. Dieser sollte jedoch nicht allzu sehr verbogen oder vergammelt sein. Alu lässt sich leicht aufpolieren.
In der Regel hat der Benziner Sb sowie der 220 immer den vollchromrahmen, die Diesel sowie die S-V die preiswertere Aluleiste.
Lieber Ralf,
die eloxierten Aluminiumrahmen mit Stoß gab es nur bei den "Sparmodellen" S-V und S-D. Alle anderen - also auch DS - hatten die geschlossenen verchromten Messingleisten. Das Gleiche gilt übrigens auch für die Zierrahmen an der Frontscheibe.
Hallo lieber Harald,
dann ist mein DS mit Faltdach wohl ein Sparmodell. Diese Alurahmen waren mit in dem Teilefundus, es gab keine anderen.
Na was soll’s , sieht auch gut aus.
