REAR WINDOW 170S W136
If you would like to post any questions or comments regarding your Mercedes 170 but you don't speak German - this is your place...
BENZNARD
Beitrag von BENZNARD »
Hello MB 170 friends
On my beloved 170S W136; I have to install a new rear window
I have the following problem
_ if I install the rear window from the INTERIOR of the car ; I have no place enough to install the wood surrounding the rear window
_Could somebody confirm me that the rear window must be installed from the OUTSIDE of the car, in order to allow the installation of the wood panel
Thank you so much
BERNARD
Re: REAR WINDOW 170S W136
Hello,
my friend and i assmebly the rear window, here is the movie about.
https://youtu.be/t416Y7ljgaQ
BENZNARD
Thank you M4
BENRNARD
Audax
Beitrag von Audax »
Hello,
just for info this will most likely not work on the smaller rearwindow. In addition it is easier to use a rope or a single flex cable (2,5mm).
Here a video with the rope :https://www.youtube.com/watch?v=ip9AMNGod6I
Sorry the video is with a beetle but it is much easier to go this way.
regards
Reinhard
