Central lubrication Vogel pump?
If you would like to post any questions or comments regarding your Mercedes 170 but you don't speak German - this is your place...
javier170SD
Beitrag von javier170SD »
Hello,
Just to be sure before disassembling my pump and try to replace the gasket to avoid oil dripping inside the body, could you identify my pump, Vogel?
With thanks for your help,
Javier
Vogel Pump_170sd.jpg (30.3 KiB) 10247 mal betrachtet
ZS Pumpe.jpg (59.28 KiB) 10247 mal betrachtet
Baloke
Re: Central lubrication Vogel pump?
Beitrag von Baloke »
Hi,
check page 11, the last mentioned pump is yours 132190.
The gasket is one thing but check carefully also the wear & tear of the entire plunger.
hope this helps you further.
br/b
ZV Vog. E-Teile, neu.pdf
(2.1 MiB) 728-mal heruntergeladen
javier170SD
Hi Baloke,
many thanks, now I know which pump it is will try to get the spare gaskets.
best regards,
Javier
