REAR WINDOW 170S W136
Verfasst: 26. Aug 2023, 22:38
von BENZNARD
Hello MB 170 friends
On my beloved 170S W136; I have to install a new rear window
I have the following problem
_ if I install the rear window from the INTERIOR of the car ; I have no place enough to install the wood surrounding the rear window
_Could somebody confirm me that the rear window must be installed from the OUTSIDE of the car, in order to allow the installation of the wood panel
Thank you so much
BERNARD
Re: REAR WINDOW 170S W136
Verfasst: 17. Mär 2024, 19:59
von M4st3r M M
Hello,
my friend and i assmebly the rear window, here is the movie about.
https://youtu.be/t416Y7ljgaQ
Verfasst: 17. Mär 2024, 21:29
von BENZNARD
Thank you M4
BENRNARD
Verfasst: 2. Mai 2024, 10:45
von Audax
Hello,
just for info this will most likely not work on the smaller rearwindow. In addition it is easier to use a rope or a single flex cable (2,5mm).
Here a video with the rope :https://www.youtube.com/watch?v=ip9AMNGod6I
Sorry the video is with a beetle but it is much easier to go this way.
regards
Reinhard
