RUCKWANDFENSTER
Verfasst: 26. Aug 2023, 22:42
von BENZNARD
Hello MB 170 friends
Sorry, unfortunately; I don't speak German
On my beloved 170S W136; I have to install a new rear window
I have the following problem
_ if I install the rear window from the INTERIOR of the car ; I have no place enough to install the wood surrounding the rear window
_Could somebody confirm me that the rear window must be installed from the OUTSIDE of the car, in order to allow the installation of the wood panel
Thank you so much
BERNARD
Re: RUCKWANDFENSTER
Verfasst: 29. Aug 2023, 20:24
von BENZNARD
Hello 170 Freunde
Nobody knows???????
Please "don't let me down
Viele danke
Gruss aus Frankreich
BERNARD
Re: RUCKWANDFENSTER
Verfasst: 3. Sep 2023, 01:12
von Lahme Krücke
Hello Bernard
Sorry, but i dont understand the Problem quit enough.
I - for example - have replaced the rear Window seal for myself on my early 170 s - without the Chrom Trim - also from the inside. And ist was no Probelm to install the Wood trim either.
Please point it out for me, if you wish.
Regards, Marco
Re: RUCKWANDFENSTER
Verfasst: 3. Sep 2023, 23:29
von BENZNARD
Hello Marc
What I want to know:
_once installed with its seal; is the rear window glass INSIDE or OUTSIDE the body of the car?
Many thanks for your help
BERNARD
Re: RUCKWANDFENSTER
Verfasst: 4. Sep 2023, 23:25
von Lahme Krücke
Uh, thats a surprisingly tough Question. I can´t remember.
Of course i have not one single Picture from the day when i install the rear Window, so i just went outside to have a look at it. But in the Dark with my little torch it was not so successful.
First impression is: the Glas is from the inside. But i have to make a closer look tomorow at Daylight to be sure.
Regards, Marco
Re: RUCKWANDFENSTER
Verfasst: 5. Sep 2023, 23:16
von BENZNARD
Thank you so much for your help and patience ; Marco
Waiting for your information
Regards
BERNARD
Re: RUCKWANDFENSTER
Verfasst: 7. Sep 2023, 01:03
von Lahme Krücke
Hello Bernard
So, im quit sure now, that the glas is mountet from the inside.
Note:
In my case i must put on some extra sealant on it, becaus the aftermarket Rubberseals are sometimes not so good in shape.
Regards, Marco
Re: RUCKWANDFENSTER
Verfasst: 7. Sep 2023, 22:33
von BENZNARD
Hello Marco
Thank you very much for your kindly help
I wish you the best
BERNARD
